Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
CB mike used for computer mike?
Reply
  #1
Old 12-02-2008, 02:38 PM
King Mudduck's Avatar
Senior Member
King Mudduck is an unknown quantity at this point
Default CB mike used for computer mike?
My mike that i use in ( just a cheap computer mike ) paltalk just crapped out on me but i have cb mikes laying around every where. So rather than spending money for a new computer mike can a cb mike be rewired so that it could be used on a computer? Be cool if i could use a D-104,bet that would have a good sound to it.
......what can i say,i'm cheap!
__________________
Government = Massive spending, Higher taxes and Shredding the Constitution!
When will enough be enough?
Worldwide Radio Forum
  #2
Old 12-02-2008, 03:18 PM
Senior Member
W5LZ is an unknown quantity at this point
Default
I'm sure there are some 'CB' mics that will work just fine. I'm also sure that there are a few that are not suited for computer use. Wanna try it? Why not.
  #3
Old 12-02-2008, 05:27 PM
mackmobile43's Avatar
Supported Member
mackmobile43 is on a distinguished road
Default
Most any old mic cartriage will do and all you need is the mic wire and the ground wire to the pc, most use a 1/8'' mono jack and just attach the mic to the center lead and the ground well you know where.
Just try several in a room with you buddies and see which one overall they seem to like then you can either internally bypass the ptt switch or not, rubber band it to make contact or just squeeze it as normally operated but I bet you find the first suggestion more to your liking.
I've been on paltalk since 02 under 1 username or another and I would not consider any other chat program, deadbeat (JAZZMAN) or paid.
__________________
fun and games
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
Search Engine Optimization by vBSEO 3.3.0
