| Home | Register | Chat Room | FAQ | Social Groups | Member Map | Search | Today's Posts | Mark Forums Read | Satellite Maps | DXSpot Map |
| | LinkBack | Thread Tools | Display Modes |
#1
| Does anyone have a source for information on the D-104 with the UG8 base. The one I have has the 4 wire arrangement, there's a diagram inside the base, but it doesn't tell you what purpose each conductor serves..... Any links or information is appreciated......
__________________ 37OH - SSV - O773H |
| Worldwide Radio Forum | |||
#3
| Thanks Sonwatcher, it's actually the T-UG8 base I have, and that's the exact diagram glued to the bottom plate. I was trying to figure out which lead performed which function so I could match the actual microphone function leads to an ethernet plug for an Icom 2m radio. The Icom has the 8 lead ethernet plug, and 4 of those leads control the function buttons on the control mic, I need to find out which leads on the D-104 will just work the PTT and voice carrier from the mic to the radio......
#4
| which type of base does a silver eagle have?
__________________ |
#5
| Astatic 4 wire: Audio = White Common = Shield Transmit = Red Receive = Black Astatic 6 wire: Audio = White Common = Shield Transmit - Red Receive = Black Switch = Blue Relay = Yellow |
#6
| Quote:
That's a helpful step in the right direction......thanks.....
#7
| http://www.tech-systems-labs.com/pdf-files/astatic.pdf this can be bookmarked for further reference also if you need it
__________________ CDX 98 In The Swamps of Louisiana Better Known As "ByuHnter" on the local Channel #1 here. "We Back Quiet" sitting on Our Cajun Limo !! |
#8
| The schematic on the bottom cover shows all the functions. Just follow it through.
__________________ BC |
#9
| Quote:
I figured it out for my Kenwood TS-130S and have been using it for quite a while now, but I might get a Heil mic for that radio, and keep this D-104 for something else. This resource will come in handy later.... Thanks again for posting it..... Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
