My Astron on/off switch lights up, small, but normal hum. Amp meter moves a tiny bit and no voltage registering. Was working fine just the other day. Fuse is still good, and all checked out fine. Unit is only four years old with very little use.
Any thoughts?
Upon further inspection, one of the power cables to my tuner had a short, which (I guess) prevented the Astron from powering all the way up. The Astron mush have some sort of sensor the prevent damage on situations like this. Changed out the cable, an all is fine!!!
