I had tried Google before I came to this site. Doesn't seem to be out there.
Anyway, I fixed the problem, bad rectifier, didn't cross to anything, so I used
a 40 Amp bridge rectifier in it's place. Being a full wave PS, I didn't use the negitive side of the rectifier.
That is a common problem among most power supplies I use the KBPC5010 for replacements and thatv usually takes care of future problems with it happening again. I was thinking when I first looked at your post that it was the dreaded rectifier failure and seen it was.
Im glad you have it up and going
__________________ """"was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
I Googled "tripplite pr-25". What came up was a list of possible hits, including a direct link to the Tripp-Lite web site, which is the link I posted earlier. It doesn't get any easier than that.
__________________ If you're like everybody else,
you're about average.
73 de K7KBN
