Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
Amateur Callsign Lookup
Enter Callsign:
D104 T-UG8 Amp ICOM 701
Reply
  #1
Old 09-28-2009, 11:54 PM
Junior Member
K4NYK is on a distinguished road
Question D104 T-UG8 Amp ICOM 701
I need to keep the 9VDC superimposed on the MIC line from the IC-701 out of the preamp in the T-UG8. The initial reccomended 'fix' is an electrolytic cap, + side to the radio, in the MIC line. I tried a junkbox 220uf (first one I grabbed) and the complaint is 'something is wrong with your mic' and 'sounds tinny'. Obviously I have created a high-pass audio situation. A reccomended value or other fix would be appreciated.
73, Louis
eMail K4NYK@schubie.com
Worldwide Radio Forum
  #2
Old 09-30-2009, 03:15 AM
Junior Member
regencycb is on a distinguished road
Smile
Quote:
73, Louis
A 10uf should be large enough. As far as the tinny sound you have an imp mismatch. You may trying inserting a 50k Ohm 1/8 watt resistor in series with the mike audio lead and capacitor . the resistor& cap could also be placed in the base of the mike in series with the white lead this should improve the lows .
Try turning the vol control on the D104 up 1/2 way and the mike gain on the radio as low as you can to get the audio output you need.
If this does not help you may have a damaged D104 mike element.
73 RCB
  #3
Old 10-01-2009, 04:23 PM
Senior Member
HiDef is an unknown quantity at this point
Default
#1 guess is a bad mic head as said. Did it work OK with the internal battery?
If that's not it are you sure it's a 220 uf and not pf. I know it sounds dumb but 10 uF is plenty to pass all the low end you will need at that input impedance.
BTW, you would probably have much better tone with a different preamp.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need Help Setting Up Radio Neuro CB Band and CB Radios 24 06-10-2009 02:30 PM
2009 Dayton Hamvention Coverage moleculo General Ham Radio Discussion 72 05-19-2009 04:57 PM
high swr when amp on. flat swr when amp off iceman78 Amplifiers 8 02-16-2009 10:34 AM
Icom 706 thru TS 500V amp? Mr. Doug General CB Services Discussion 10 02-03-2009 08:59 PM
ICOM IC-V8 Happy_Hamer General Ham Radio Discussion 1 11-24-2006 08:14 PM
Powered by vBulletin®
