Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
Amateur Callsign Lookup
Enter Callsign:
astron 70 amp ps. problem
Reply
  #11
Old 10-10-2009, 04:52 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
Quote:
Originally Posted by Splash1 View Post
Mac..the meter on the astron shows drawing 45 amps with a whistle..
Then the meter is obviously wrong or you have a defective ps, do the math, 200 watts divided by 13.8 volts is only 14 amps @ 100% efficiency.
__________________
I U 212
Worldwide Radio Forum
  #12
Old 10-10-2009, 05:54 PM
Radio Tech's Avatar
Radio Operator
Radio Tech is on a distinguished road
Default
Sounds like the supply has bad regulation. Could be one of the series pass transistors is leaking. I have several Astrons and none dim. Even pulling half the load.
  #13
Old 10-12-2009, 07:14 AM
Senior Member
DXman is on a distinguished road
Default
Quote:
Originally Posted by mackmobile43 View Post
A 70 amp supply will run that radio no problem especially since the radio only uses 14 amps or less.
Mack,
The n2 model radio will draw over 45 amps just modulating (this is on ssb)
I can not run my 2970n2 at full power using a 50 amp supply set @ 14.1, the radio will shut down.
It's no problem on AM, it draws around 28 amps if I remember right.
__________________
CDX 178
WR 178
2SD178
  #14
Old 10-12-2009, 02:04 PM
Senior Member
Splash1 is an unknown quantity at this point
Default
up date..called astron co. today and they told me its normal for the lites to dim as the lites are wired befor the regulation and or the transformer..he said its also normal for the bottom to get hot and the fan not to come on..he said the fan wont come on untill the heat sink by the meter gets to 140 degres..the bottom of mine gets hot but the sinks have always been cool....so,, if anyone has one of these and you were worried about the symptoms i had,,i guess its nothing to worry about..so i guess i gotta eat my words bout ''buyer beware'',,mmmmm, they kinda taste like chicken..
__________________
splash..
  #15
Old 10-12-2009, 09:16 PM
Prestigious Member
Default
Quote:
Originally Posted by DXman View Post
Mack,
Doesn't matter what kind off radio it is, 200 watts is 200 watts and unless it's @ - efficiency 200 watts only draws 14 amps or so @13.8 volts.
My ts-430s kenwood uses less than 20 amps @ 200 watts in ssb mode and that's on a astron rs-20a power supply now debunk that.
__________________
I U 212
  #16
Old 10-12-2009, 10:24 PM
Senior Member
Default
This is true what you say above...but just about all these radio will do close to 300 peak on modulation, some have been know to do 300 +.
I have listen to several of the N2 models on the air and everyone of the guys that are using them, are using a 70 amp supply to run the radio.
When I first got mine a few weeks back, I hooked it up to a 36 amp PS, on first key it pegged the needle and almost stopped the PS. I am now running the radio on a 50 amp ps, but can only run the power setting at the lowest point, which is around 200.
Soooo, I either detune the radio or go for a bigger supply.
__________________
CDX 178
WR 178
2SD178
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need Help Setting Up Radio Neuro CB Band and CB Radios 24 06-10-2009 02:30 PM
Kl-203 Amp Mods? California Kid Amplifiers 5 05-18-2009 11:31 PM
high swr when amp on. flat swr when amp off iceman78 Amplifiers 8 02-16-2009 10:34 AM
Coax for Mobile Installation with Amp this_is_nascar Installation & Station Setup 7 02-14-2009 06:20 AM
Astron Power Supply problem Sonwatcher Tech, & Repair 5 11-26-2007 03:50 PM
Powered by vBulletin®
