Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
Amateur Callsign Lookup
Enter Callsign:
PEAK & PEP
Reply
  #21
Old 10-14-2009, 12:33 PM
dudmuck's Avatar
Senior Member
dudmuck is an unknown quantity at this point
Default
Quote:
Originally Posted by unit_399 View Post
The RMS value is equal to the peak value times 0.707.
That is true only for a sine wave.
Voice is not a sine wave, and voice is not symmetrical.
3 ways of expressing voltage of a common AC wave form
__________________
"Y'all mind hanging back? You're jamming my frequencies" -- Tangina in Poltergeist
Worldwide Radio Forum
  #22
Old 10-14-2009, 12:56 PM
Wire Weasel's Avatar
Honkus Maximus
Wire Weasel is an unknown quantity at this point
Default
Viewing a pure symmetrical sine wave (with no dc bias) on an oscilloscope, the total vertical displacement (maximum positive TO maximum negative) is the PEAK to PEAK voltage. In the same symmetrical waveform, the maximum positive OR maximum negative excursion is called the PEAK voltage, and it is one half of the peak to peak reading. The RMS value is equal to the peak value times 0.707. For example, home electricity is 117V rms, 165.5v peak , and 331v peak to peak.
- 399
That's some fine brainiakin' boys
__________________
Supplying All Your Wire and Weasel Needs Since 1869 * All Orders Come With A Free Pack Of Vazomyne For Sustained Performance
  #23
Old 10-14-2009, 01:24 PM
C2's Avatar
C2 C2 is offline
Senior Member
C2 is on a distinguished road
Default
Quote:
Originally Posted by Beetle View Post
PEAK power can only be determined for waveforms that are relatively constant, such as power lines at 60 Hz. With purely sinusoidal, constant level waveforms, the math is a snap - and you can easily measure it with a calibrated oscilloscope.
PEAK ENVELOPE POWER (PEP) is a little more complex, since it involves the waveform as modulated by a human voice or by a multitone audio signal. RF wattmeters typically measure average (not RMS) power. There are some meters that have a "PEAK" position on their switches, but these are NOT reliable in that switch position.
Meters that will accurately read PEP must have active circuitry to analyze the RF waveform, do the math, and display it on the instrument's face. In order for the instrument to do that, it needs to have either an internal battery, or an external power source, to provide the power for that active circuitry.
Some MFJ meters (and others, I suspect) have wallwarts available that will power the lights for the meter face. Check the specifications carefully and ignore switch position markings. You're the buyer, so beware.
I think it is possible to measure peak power of any kind of RF energy, constant or not...
  #24
Old 10-14-2009, 01:35 PM
C2's Avatar
C2 C2 is offline
Senior Member
Default
Quote:
Originally Posted by QRN View Post
I think you and I just read the same post.
I guess the easiest and most basic way to define it is that peak power is the peak or greatest power output that is delivered to a load at any time during operation. Peak envelope power is the average power supplied to the antenna transmission line by a transmitter during one radio frequency cycle at the crest of the modulation envelope, under normal operating conditions of an amplitude modulated waveform. Peak is relativley easy to measure. Pep is not quite so easy.
I'm confused...
While I agree that peak power is the peak or greatest power output that is delivered to a load at any time during operation.
Wouldn't this value be just as difficult to determine as PEP?
  #25
Old 10-14-2009, 03:25 PM
unit_399's Avatar
Bigstrapper
unit_399 is on a distinguished road
Default
QRM's definition is correct. For a quantitative explanation of Peak vs Peak-to-Peak
check this link.
www.cbtricks.com/members/kd6tas/amsig.htm
  #26
Old 10-14-2009, 04:54 PM
Beetle's Avatar
Senior Member
Beetle is on a distinguished road
Default
Who's "QRM"?
__________________
If you're like everybody else,
you're about average.
73 de K7KBN
  #27
Old 10-14-2009, 07:16 PM
mackmobile43's Avatar
Prestigious Member
mackmobile43 is on a distinguished road
Default
Who's "QRM"?
This thread is full of it who ever it is.
__________________
I U 212
  #28
Old 10-14-2009, 07:18 PM
unit_399's Avatar
Bigstrapper
Default
Who's "QRM"?
I meant QRN... sorry.
QRM ??? I don't know him either. Some day I will learn how to type.
- 399
  #29
Old 10-14-2009, 08:32 PM
TonyV225's Avatar
Senior Member
TonyV225 is on a distinguished road
Default
I think thberes 2 QRM's I hear them everynight on 80 meters when the group I belong to tries to talk.
__________________
""""was not thinking of a cber sat with his makita screwdriver winding round the presets untill his meter said s9+60db from a guy on a handheld 15 miles away""""
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
D&A Warrior 1000 LoneWolf TN Amplifiers 15 11-13-2009 11:00 PM
peak and tune bigred222 CB Band and CB Radios 8 01-05-2009 01:58 PM
Galaxy DX 88HL HELP!!!! hank Tech, & Repair 5 11-29-2007 08:08 PM
midland 1001z peak & tune how anixon92 Tech, & Repair 0 11-17-2007 06:13 PM
peak and tune........worth it???? thumbs1 CB Band and CB Radios 4 02-02-2002 08:28 AM
Powered by vBulletin®
