I doubt whether a preselector is going to do you much good. A preselector's primary function is to peak a selectable frequency at the receiver's antenna terminals and reject (or just not peak) adjacent signals.
If I'm understanding your question, you seem to have quite a bit of background noise/electrical hash. That's a pretty equal-frequency-opportunity problem. The preselector may boost a signal that's mired in the noise, but it will boost the noise level it perceives as being on that frequency as well.
And as W1EMQ said, with something like the QF-1, you can narrow the bandwidth. Problem there being, if you narrow it too much, you won't be able to understand what's being transmitted. Unless it's a CW signal.
__________________ If you're like everybody else,
you're about average.
73 de K7KBN |
