Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > Tuners, Mics, Meters & other Accessories
Amateur Callsign Lookup
Enter Callsign:
ASTATIC PDC 2
Reply
  #1
Old 01-17-2011, 05:58 PM
Junior Member
WEIGHTMAN is on a distinguished road
Default ASTATIC PDC 2
looking for how to use it, the instructions with it suck, i dont know what the little antenna on it is for, or which scales to look at, each screen has 3 scales to look at, i hooked it up and it says my watts drop off when i talk, does that make sense, any help wouyld be appreciated
  #2
Old 01-17-2011, 06:13 PM
359's Avatar
359 359 is online now
Senior Member
359 is on a distinguished road
Default
LINK
  #3
Old 01-17-2011, 06:14 PM
Jock Supporter
mackmobile43 is on a distinguished road
Default
Quote:
The little antenna is for the field strength portion of the meter, the scale on the left is the power reading meter depending on which setting you have it on which is either 0-10 watt scale and the other setting is 0-100 watt scale so if you're checking a normal cb radio you set it to forward 10 watt scale and you can read your swr (standing wave ratio) on the meter to the right.
If it's your power reading is going backwards you may have it set to reflected wattage function which indicates power radiated back into the radio which is never good.
  #4
Old 01-25-2011, 03:52 PM
Junior Member
Default
ive tried 2 other radios on it 1 other coax, 3 other antenas, the rsults are the same, should i stay keyed up when switching fromfwd to ref thanks
  #5
Old 01-25-2011, 03:57 PM
Robb's Avatar
Yup
Robb is on a distinguished road
Default
SWR
__________________
BASE: Kenwood TS-2000, GAP Titan DX, Diamond X50A, Sirio SY27-4, and IMAX 2000.
MOBILE: Galaxy DX99V w/RF Limited CR-577 mic, Sirio Z-180. Yaesu FT-8800R & Diamond NR-770.
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Astatic 636L vs. stock Cobra Mic. Steve H Meters, Mics & Other Accessories 4 11-10-2010 05:11 PM
Astatic 1104c Mister Heat Meters, Mics & Other Accessories 4 08-08-2006 04:18 PM
Barjan now owns Astatic NorthStar Announcements & Open Forum 15 07-28-2006 09:17 AM
Powered by vBulletin®
