Quote:
can u use Motorola radios for ham? if so how?
Sure you can. I have used Motorola, Vertex, Midland, E.F. Johnson and Uniden commercial radios for ham radios over the years.
How you do it is not usually that simple, because these commercial (LMR) radios do not have VFO capability, and usually require they be programmed by a computer and software. The software for some radios can be found online, since many of the radios they program are no longer made, and the software is essentially in the "public domain". Motorola, however, is very particular about it's software and doesn't like it freely distributed, so that makes programming a Motorola radio a bit more challenging.
Also, most Motorola dealers will not reprogram a radio into the amateur band, since the radio was not "designed" for those frequencies, even though they will usually work there fine and without retuning. Motorola is not a friendly company, and they come down hard on people about licensing agreements and software piracy.
I did my Moto radios myself by obtaining the necessary software, the necessary programming cables, and in some cases, performing the necessary hex edits to the software code so as to be able to enter in the particular frequencies for the ham bands (as is required to program the GTX line of 900 mhz radios to work on the 33cm ham band).
So, yes, you can use Motorola radios for ham radio, but you need to jump through some hoops to use it.
