Quote:
If you set up yer mobile to use chan A for input and chan B for output to and from your HT.
When you TX on the HT, you are ID'ng for the transmission on chan A
However when the repeater traffic comes back to you, your mobile is now sending it on chan B, not the repeater output, but the output of YOUR repeater. |
I disagree with you.
Let's use real frequencies for demonstration purposes.
My
HT is set to
TX and
RX on 444.00. The repeater input is on 145.00 input and 146.00 output. That means my crossband repeat rig is set on 444.00 on one band and 145.00/146.00 on the other band. When I key my
HT and ID, it will be heard on 444.00. The crossband rig will hear it on 444.00 and
tx it on 145.00. Now my ID has been heard on two frequencies I'm using. Then the repeater picks it up on 145.00 and sends it to the output on 146.00. Now my ID is on three frequencies. While I'm keying my
HT my crossband repeat rig is busy
RX on 144.00 and
TX on 145.00 so it cannot also be
RX on the repeater output of 146. When someone else talks back to me and IDs, my crossband rig hears 146.00 and sends it back to 444.00. Now their ID was heard on the repeater input of 145.00, the repeater output of 145.00 and my crossband/
HT freq of 444.00. The other station I'm talking to has also now ID on all the frequencies they've talked on also. My ID doesn't have to come out of my crossband rig on 146.00 because I have never
TX out of it on 146.00. It has, however come out of the repeater on 146.00 which is where it was broadcast from. It really doesn't make any difference, because I have fullfilled the requirement to ID on all frequencies I
am using. The rules don't specify which rig has to do the ID'ing.
Quote:
On your output, it is active any time there is traffic on the other system.
So what. Everyone IDs when they're supposed to and their ID is heard on all the frequencies in use. My id was heard on my output because that's also the same feq my
HT is
TX on, which I already ID'd on. There's no requirement that IDs are heard on every transmission, only every 10 minutes.
Quote:
You aren't IDng on that output frequency you are only heard with ID on the system you are linked to and on your input frequency.
The output of your crossband is still unidentified.
NO. The repeater broadcasts my ID on it's ouput, my crossbander broadcasts my ID on both of it's outputs, and my
HT broadcasts my ID on it's output. Just because the other stations don't "hear" all the frequencies it's being
TX on doesn't mean it's not being
TX.
