Quote:
Originally Posted by moleculo If you can walk over to the crossband rig to turn it off, then you have control of it. If you give you're giving your callsign out at appropriate intervals then your ID is being given on every frequency that your radios are operating on. Just turn the crossband rig off when you're done with it and it won't be transmitting when you're not there.
Oh, and can someone please tell me where in the regs it says that a personal auxilliary or repeater station must have a key-down timer, a remote control shut-down mechanism, and an automatic repeater id message? Maybe it's there and I just don't know where? |
O.k. if you are doing full duplex crossband, it looks like this
you -> input frequency to your mobile -> output on the input of the repeater
repeater -> output frequency picked up by your mobile -> mobile outputs to the output you configured for your duplex on receive
The problem is your mobile when it is relaying the repeater back to you, isn't identifying. When you transmit in, you are ID'ng for you on the repeater, but the repeater outputs on your duplex channel are not IDd and that's the issue. It's an unidentified transmission the whole time it's running.
Not sure what part of the
FCC regs covers repeater ops offhand, but you are required to have a means of remote shut-down and recently they now require that you cannot solely use an input RF channel to do this. (This does refer to full time repeaters or unattended operation more accurately.)
You must have an 'out of band' alternative, a link control on another band or a telephone line you can dial in with.
This is so that if the equipment malfunctions you can stop the interference on the band remotely.
Also, due to issues with jammers tying up RF control links, that's why they added the additional stipulations.
The key-down timer, I'm not sure of. Most repeaters have a 3 minute or shorter time out timer, but I'm not sure if that is for best practices or if it is also required.
A LOT of problems occur in the NJ/NY metro area with people not understanding their gear or the band plans when they pick frequencies for personal link setups.
Problems range from people using outputs of existing repeaters as their input, creating unidentified loops between repeater networks.
People setting up 'full time' rogue repeaters that interfere with coordinated pairs.
People setting up repeaters on simplex frequencies or OSCAR sub-band frequencies.
People setting up inputs or outputs that interfere with RF link channels....the list goes on and on.
If you are anywhere near a metro area, you *must* have a full understanding of what you are doing before you bring a linked setup on the air. It's well beyond reading the manual and enabling the feature on a radio.
There is pretty aggressive enforcement with guys using commercial communications quality DF equipment to hunt sources of interference around here and people get cited fairly frequently. A lot of the repeater coordinators and control ops work in the communications field and have access to crazy amounts of high-end instrumentation so it's simple for them to track people down.
