Don't confuse "duplexer" and "diplexer".
Duplexers for the same frequency, or very close bands of frequencies, are not common. At least these days. Back in the '60s, Navy ships used duplexers to put up to five 1KW transmitters on the same antenna at the same time, with less than half a dB loss on any circuit.
A "diplexer" is what you'd use to have simultaneous 2 meter and 70 cm capability with one antenna. Frequencies are widely spaced, so you don't need a duplexer.
__________________ If you're like everybody else,
you're about average.
73 de K7KBN |
