Go Back   Worldwide DX Amateur Radio Forums - Ham - CB - HF - VHF - UHF > Amateur Radio Related > VHF/UHF Bands and VHF/UHF Rigs
Amateur Callsign Lookup
Enter Callsign:
VHF Radios sharing an antenna
Reply
  #1
Old 10-31-2008, 01:31 AM
Junior Member
pelllagic is on a distinguished road
Default VHF Radios sharing an antenna
Hi All
I would like to find out whether it is practical to use two VHF Radios through a shared antenna. I have limited space on the mast of the yacht I work on and need 5 or 6 VHF units (It's a BIG yacht!)
My question is this...
If we receive a call and it is heard on the Bridge and in the Crew Mess will the Crew Mess radio be able to hear the reply made from the Bridge and therefore ignore the need to reply... Or will they not hear it, reply and confuse the calling station with a second reply...?
Any Help gratefully received
Thanks
Richard
Worldwide Radio Forum
  #2
Old 10-31-2008, 07:59 AM
Supporting Member
W5LZ is an unknown quantity at this point
Default
Richard,
As proposed, it's not something you want to do. Yes, two radios can share an antenna. But if those two radios are on the same frequency or channel at the same time, one of them will certainly get a 'shock' when the other transmits, which is not good, and is sometimes 'fatal' for the one getting that 'shock'. There are ways around that situation which can be quite expensive radio wise. Probably the simplest is the proper use of the crew. The 'snipe' ain't the navigator and shouldn't try to act like one. Same for the radio operator, etc, etc. Sounds like you may be short crewed.
  #3
Old 10-31-2008, 10:43 AM
C2's Avatar
C2 C2 is offline
Senior Member
C2 is on a distinguished road
Default
I've wondered about sharing an antenna too.
I have an OK antenna switch (forget which brand, maybe MFJ). It looks like it grounds the unused port, but I'm still concerned about about overloading the radios receive when the other transmits.
  #4
Old 10-31-2008, 10:47 AM
C2's Avatar
C2 C2 is offline
Senior Member
Default
Another idea I just had for the OP, is there a "smart" switch that will ground the input quick enough if another radio keys?
Or, perhaps more likely, a fast switching attenuator connected to each radio? Then all radios would be able to hear both the transmission without overload and any other received signal from abroad.
  #5
Old 10-31-2008, 11:25 AM
Senior Member
moleculo has disabled reputation
Default
C2:
Shakespeare AS-2 VHF automatic switch
Shakespeare Marine Electronics and Data Systems - StyleAS-2
This automatic switch toggles two radios to one antenna. When you key the microphone on one of the radios, it switches the antenna to it… automatically. The radio stays locked onto the antenna until the automatic switch detects a transmit from the other radio. Easy!
  • Specifications:
  • Frequency Range: up to 600 MHz
  • VSR: Below 1.2:1
  • Power Rating: 30 W
  • Impedance: 50 ohms
Pellagic, this isn't the solution to your problem. When this switch is set on one radio, the other radio isn't going to hear anything, either. I don't see how you're going to get around installing another antenna.
  #6
Old 10-31-2008, 03:17 PM
bit_pit is on a distinguished road
Default
Just to throw something into the ring, and I don't know (or want to know) the legalities of such a setup...
But what about a crossband repeat setup?
i.e., Single main VHF/UHF unit that does wideband and cross repeater activated(I know some of the Alinco range did this, and were easily modifiable to do VHF marine, likely other brands as well, or a custom setup with 2 radios).
Unit recieves VHF transmission, repeats it onto UHF (PMR frequencies?) and you carry round UHF Hand helds. Respond on UHF via the hand held, it gets repeated back to the VHF frequency out the main unit. All crew with UHF hand helds would hear the conversation....
I've done similar, albeit on Ham bands for field days etc.
  #7
Old 10-31-2008, 03:23 PM
Senior Member
park is an unknown quantity at this point
Default
You need a duplexer.
__________________
Everyone drives like crap but me.
  #8
Old 10-31-2008, 04:12 PM
Captain Kilowatt's Avatar
Administrator
Captain Kilowatt is on a distinguished road
Default
Quote:
That won't work when both radios are tuned to the same frequency or anything close to that ie VHF channel 16.
__________________
Front/back ratio comes from the antenna. Forward gain comes from the wall socket.
  #9
Old 10-31-2008, 05:34 PM
Supporting Member
Default
The cross banding thingy will work. There are commercial systems of that type. The catch is that they certainly aren't free. Considering the use, I'd find a commercial shop to do the installing, this really isn't something to 'DIY'.
  #10
Old 11-01-2008, 07:21 AM
Administrator
Default
I would consider remoting a separate microphone and speaker to control the one radio. At the radio station where I worked we had about a dozen places in the building with microphones and speakers that all connected to a base station located in an equipment rack. Since we had so many speakers we used a distribution amp with 70 volt transformers but the microphones were basically in parallel. For a two or three speaker system you could just parallel them all. That would allow remote monitoring and eliminate the problem of two radios into one antenna.
__________________
Reply
Bookmarks
Tags
antenna, shared, vhf
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by vBulletin®
