Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > VHF/UHF Bands and VHF/UHF Rigs
Amateur Callsign Lookup
Enter Callsign:
KENWOOD TM-241 A
Reply
  #1
Old 04-20-2009, 12:11 AM
Junior Member
elmanoduarte is on a distinguished road
Default KENWOOD TM-241 A
Hi
I īm tryng to open RX and TX in my KENWOOD TM-241 A, alredy got it for RX, by cuting the GREEN wire in the Control Painel and RESET CPU, now for TX not geting there !!
Can anyone help me ???
Thanks
73ī
  #2
Old 04-21-2009, 04:45 PM
Senior Member
Slim is on a distinguished road
Default
Are you "positive" the correct wire was snipped? Only reason I ask,is I did
my 261A and it didn't work. I then went back for some more homework and
discovered the website I got my info from was incorrect! So,I tried the "new" info and I had success. I don't recall the (correct) website now as that has been several years ago.
Good Luck.Slim.
  #3
Old 04-22-2009, 04:02 AM
Junior Member
Default yes
Thanks for answer.
Well i think it was the corect wire,,the green one!..because i did the same in a TM-241 E and it work fine, but the 241 A its diferent bout frequencies, got 118mhz and the E version (europ) donīt. Soo i cuted the same wire i saw in the other. And it open full RX, but TX just at 152mhz!,,about Install an MA141A chip diode in D209 on the Control Board, itīs alredy there from original! that put me confuse. Have any idea ???
..but do you remember what you did in your model ?,,mabe it will be the same!!
  #4
Old 04-22-2009, 10:41 AM
Captain Kilowatt's Avatar
Professional Amateur
Captain Kilowatt will become famous soon enough
Default
This is from ArtSci edition #8A:
For simple MARS mod giving 142-151 MHz simply cut the green wire.
For expanded coverage typically from 138-165 MHz you need to leave D209 installed and REMOVE D206, D207, and D208. reset CPU by holding [MR] and turning power ON. No mention of cutting the green wire for this mod.
__________________
There are 10 kinds of people in this world. Those that understand binary and those that don't.
  #5
Old 04-22-2009, 07:40 PM
Junior Member
Default iīll try
ok thanks, iīll try that, hope it work, or good bye 241 :|
  #6
Old 04-24-2009, 03:06 PM
Junior Member
Default DON`t WORK
Guys,,,that doesnīt work at all!!!,,it was a luck, to put everyhting like it was!,,after taking out D206 D207 and D208 YES it start doing full TX 136 to 174,,but its the end of RX ! no RX at all ! puting everything like it was,, back to normal,,and no full TX. Soo i still in the 1st step ! how can we do it ?
  #7
Old 06-12-2009, 11:26 PM
Senior Member
Chong is on a distinguished road
Default
i had this same radio and tryed several different things to modify it none of which worked. let me know if you find the mod.
__________________
I couldnt think of anything to put as my signature so i just typed this have a nice day!
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
LinkBacks (?)
LinkBack to this Thread: http://www.worldwidedx.com/vhf-uhf-bands-vhf-uhf-rigs/33570-kenwood-tm-241-a.html
Posted By For Type Date Hits
Kenwood VHF TM241A | VIRGILIO Ricerca | Web This thread Refback 11-01-2009 10:12 AM 7
keenwod 241a | VIRGILIO Ricerca | Web This thread Refback 10-28-2009 03:19 PM 2
kenwood 241 | VIRGILIO Ricerca | Web This thread Refback 10-01-2009 03:10 AM 2
Kenwood 241 This thread Refback 07-02-2009 11:20 AM 6
Powered by vBulletin®
