Quote:
Originally Posted by C2 What if I had two HTs and I tx on one and then every 10 minutes pick up the other just to ID; is that OK? |
No, not OK. You think your ID is going out with the "nearly identical" transmission. C2, I don't know what side you were taking on that point but it is a good question.
Quote:
Originally Posted by C2 I consider a "station" as inclusive of the antenna AND exclusive of other stations; i.e., two HTs constitute two different stations and each must ID their transmissions. |
Agreed. Both need to be identified, both are going to have different operating characteristics.
Quote:
Originally Posted by C2 In your case, I belive that the base station must ID on 440, even if you have crippled the base station's antenna and presume that your HT (many feet away) will cover the same TX range. The first part of this statement is also important, "No station may transmit unidentified communications or signals, or transmit as the station call sign, any call sign not authorized to the station." |
Here is the catch, we are pretty sure that we have got things covered but the stations are not (and can never be) identical.
Quote:
Originally Posted by C2 I do not believe that I could set up my base station to auto ID every 10 minutes and then walk around my property all day TXing on my HT and never ID, and still be legal, even if it was all done on the same frequency. |
Err, right. But that is not what Moleculo's how to describes, or suggests doing.
Quote:
Originally Posted by moleculo I disagree completely. Look at it this way: I have two HF antennas installed that cover some of the same bands. I have a coax switch that allows me to switch back and forth between them depending on which one I feel like using. If I apply your reasoning, then I must make sure I ID on each antenna I talk on. |
Yes, identify on each antenna.
Quote:
Originally Posted by moleculo However, If I'm talking on one antenna and then start talking to a different station and switch antennas because it allows me to hear that station better, there is no requirement that I switch back the first antenna I started on and ID there within ten minutes. |
Err, right. I wouldn't think you would have to, unless you wanted to
TX on that first antenna again. But you would want to identify whilst using the second antenna.
Quote:
Originally Posted by moleculo If you with your HT and your base operating at the same location, then yes as long as it's being done on all the frequencies in use. This is exactly the reason why some of the newer crossband repeat rigs started coming with the ability to auto-id on both bands. |
Ya, sounds good.
Quote:
Originally Posted by moleculo The rules don't say that you have to ID using every radio/antenna/piece of equipment that you operate on at the station. It says that the Control Op must ID on every frequency in use and you can do it using CW or whatever other mode you're using. |
If that is the rule, then OK...
Quote:
Originally Posted by moleculo The distinction that you're making is that you believe that your HT is a self contained station separate from the base. I'm saying that when you set it up like I have described, it is now a single, integrated system and as long as long as you're within a distance that you can easily control both rigs in use, you are at the station control. |
I think that each station should still be
TX'ing the ID though, which sounds like it does if there is an auto-id.
I think the operator/owner should be ID'ing on
each TX frequency from
each transmitter. It sounds like the rules leave enough room to allow a few ways to get that done (which is part of what some of the argument has been about). Why
should the operator/owner ID on each transmitter frequency? Regardless of what the official rules say (they are confusing), I think the transmissions should be identifiable if someone wanted to contact the owner (by other means) if there was a problem with one of the transmitters. So ID'ing from the
HT on 440.00 and having that same transmission
TX'd again from the repeater is OK, but as soon as the repeater wants to
TX again on 440.0, there should be another ID I think. Unless you are sure that your
HT does provide greater coverage, and the repeater operating correctly.
An example why,
Similar to the first quote above by C2, I wouldn't
TX ke7vvt on my 8r, set it down, pick up a new mic and then take up a conversation on a home brew repeater with a low gain antenna (I really
am brewing one) without TXing my ID again. There is no way that I would get it (the repeater) right the first time!
Moleculo's idea of dumbing down the range of the crossband repeater on the 440 side does sound like it should make the system work, especially if your pretty sure everything is working correctly (which is where other parts of argument have come from) But is it really legal? I don't know, I don't care if someone else does it, you and your station and the other person you are talking to are bound to reveal ID's at some point and you probably will be able to be contacted if something goofy is happening. I wouldn't try that suggested antenna/duplexer technique without the auto-id, but only because I know I wouldn't do it right. If you are doing it and everything is working great then kudos!
I think the Kenwood D-710 might be able to do this. We usually have an operator at that "base station" on our expeditions, so even if it doesn't auto-ID on the output back to the
HT's, the operator can ID for it. Thanks a for all of the great info from all parties esp. AE7RS, Moleculo, and C2.
edit: Kenwood D710 does do cross band repeat, and it looks like it can do single band also (if you set it up right I imagine)
