Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > VHF/UHF Bands and VHF/UHF Rigs
Amateur Callsign Lookup
Enter Callsign:
Yaesu FTM 350R setting up the time
Reply
  #1
Old 09-08-2010, 12:51 PM
Junior Member
rhyary is on a distinguished road
Default Yaesu FTM 350R setting up the time
When I set up the time on the 350, it reverts itself to 1 hour back.
I doubled checked my time zone five times and it is correct.
I tried with Tim signal on or off.
I have the GPS option.
I set the time, it is correct for a some minutes and than revert it self to one hour back.
What am I missing?
__________________
YAESU FTM-350R
1996 LX450
  #2
Old 09-08-2010, 01:28 PM
Senior Member
Hutch is on a distinguished road
Default
Daylight Savings Time setting?
  #3
Old 09-09-2010, 09:09 AM
Junior Member
Default
Tech support days to upgrade the firmware.
I should get the cable today and will do that tomorrow.
__________________
YAESU FTM-350R
1996 LX450
  #4
Old 09-10-2010, 05:24 AM
Junior Member
Default
I upgraded the firmware this morning and it is doing the same thing.
It does not just go back one hour.
If it shows 7 O'Clock and I set it to the correct time, it goes back to 7 O'Clock.
if I set it to 9 it goes back to 7, not to 8.
I think it gets the time from the GPS and somehow it does not know to move it up one hour.
It does sounds like a day light saving issue, so when the clock will "fall" behind one hour it should be OK. But I did not find anywhere Day light savings option.
__________________
YAESU FTM-350R
1996 LX450
  #5
Old 09-10-2010, 03:03 PM
Senior Member
Qwazyone is on a distinguished road
Default
Could it be that with no DST setting that you have to change the time zone compared to Zulu(GMT). I am in the Central time zone, normally GMT -6 hours but during DST I am GMT -5 hours
Reply
Bookmarks
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Yaesu FTM-350 APRS Review Moleculo Product Reviews 89 03-25-2013 07:29 AM
Yaesu FTM-350 Alignment Procedure Moleculo VHF/UHF Bands and VHF/UHF Rigs 6 02-10-2011 11:36 AM
New Yaesu FTdx 5000 Preview Moleculo HF Bands and HF Rigs 12 02-12-2010 08:23 PM
Yaesu FTM 350 va2rp VHF/UHF Bands and VHF/UHF Rigs 1 01-25-2010 09:56 AM
Yaesu VX-8r volume setting helps mobile use Moleculo HandiTalkies 3 08-21-2009 09:22 AM
Powered by vBulletin®
