Go Back   WorldwideDX Amateur Radio Forums > Amateur Radio Related > VHF/UHF Bands and VHF/UHF Rigs
Amateur Callsign Lookup
Enter Callsign:
New Yaesu FTM-350 programming software by G4HFQ
Like Tree1Likes
Reply
  #1
Old 09-28-2010, 11:47 AM
Moleculo has disabled reputation
Default New Yaesu FTM-350 programming software by G4HFQ
G4HFQ has just released a new application to program and manage the Yaesu FTM-350. I was fortunate enough to receive a beta copy of the software while it was in development and have also received the released version. It works excellent and the best part is that it is only $15!
Here are a few of the key features:
  • Backup/restore of the FTM-350 clone memory
  • Modify memories
  • Add/delete/move memories
  • Manage memory banks
  • Cut/copy/paste memories
  • Sort memories by frequency or name
  • Analyse and report on duplicate frequencies
  • Edit PMS memories
  • Edit VFOs
  • Change the values in the radio's menus and APRS/GPS settings
  • Print memories
  • Import/export using CSV and TravelPlus.
An FTDI chipset USB/Serial cable is required.
Here are a few more screen shots:
You can download a trial or purchase from: G4HFQ Software - FTB350 Details
  #2
Old 09-28-2010, 12:53 PM
depark's Avatar
depark is on a distinguished road
Default
Quote:
Does the RT Systems cable work? Also how does the software compare to the RT Systems version (Ease of use, General layout, Manual)? I just looked at the
G4HFQ website and one feature I really like is to be able to transfer files between different radio versions. My club has a default load for their FT-7800's, with this software I can load it to my 350.
__________________
73 Darryl VA7DTP
Portable: Yaesu VX-8DR
Mobile: Yaesu FTM-350R & Comet CA-2x4SR
Base: Icom 746Pro & Chameleon V22L Multiband antenna
MFJ-993B Auto Tuner / RigExpert Ti-5
  #3
Old 09-28-2010, 08:31 PM
Default
I'm not sure. I don't have the RT Systems FTM-350 software and cable. I looked at the driver for their VX-8 cable (they all use the same driver) and it is an FTDI chipset driver. However, it doesn't present itself as a COM port, so it may not work. Download the trial version and see if you can get it to read the radio with your cable.
  #4
Old 09-29-2010, 09:00 AM
Junior Member
KC5NOI is on a distinguished road
Default
AWESOME Moleculo! Thanks for posting, I will buy this software tonight! I really hope that the G4HFQ software I currently use for my FT-8800 can export the memories to the 350 using the new G4HFQ software?? If so, that will save a HUGE amount of time re-entering all of my memories. Please tell me if you know it works this way!
This is what makes me think so, taken from G4HFQ's website...
The Import/Export facility enables you to exchange memory information between the following radios by using .CSV format memory definition files. You will also need to use the appropriate FTBxxx software for the target radio.
FT-817, FT-847, FT-857, FT-897 (including ND and D models), FT-1802, FT-1807, FT-1900, FT-2800, FT-2900, FT-7800, FT-7900, FT-8800, FT-8900, FT-60, FT-250, FT-270, VR-5000, VX-3, VX-8, VX-110, VX-150, VX-120, VX-170, VX-177
VX-2, VX-5, VX-6, VX-7 - using the Commander range of software by Jim Mitchell, KC8UNJ
Thanks!
73' KC5NOI
Matt Skinner
  #5
Old 09-29-2010, 09:47 AM
Junior Member
NY ESU is on a distinguished road
Default
Quick question. The current radio firmware version doesn't allow for traditional "memory banks" in the FTM-350. Many users have cited this as a drawback of the radio.
I notice the description includes "manage memory banks." I assume this translates to either the left or right side single memory bank of each of the two receivers, not anymore that the software creates. Is that accurate?
  #6
Old 10-07-2010, 10:07 AM
Junior Member
Default
Quote:
Originally Posted by KC5NOI View Post
.....I really hope that the G4HFQ software I currently use for my FT-8800 can export the memories to the 350 using the new G4HFQ software?? If so, that will save a HUGE amount of time re-entering all of my memories. Please tell me if you know it works this way!....
Just wanted to post that exporting the .csv file from my FT-8800 and importing it into the FTM-350 worked perfectly! Saved a LOT of time!!!
73's KC5NOI
  #7
Old 10-07-2010, 11:59 AM
Default
Yes that is correct. It doesn't provide any new functionality to the rig.
  #8
Old 10-27-2010, 06:13 AM
Junior Member
Default
Thanks.
Reply
Bookmarks
Tags
g4hfq, yaesu ftm-350
Worldwide Radio Forum
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FS: Yaesu FTM350R w/gps & Programming Software Wise87 Amateur Radio Gear Swapshop 1 09-29-2010 09:23 AM
RT Systems Software for Yaesu VX-8r Review Moleculo HandiTalkies 15 06-20-2010 05:30 PM
Yaesu FTM 350 va2rp VHF/UHF Bands and VHF/UHF Rigs 1 01-25-2010 09:56 AM
Programming Software for the VX-8R archangel HandiTalkies 23 05-27-2009 10:49 AM
yaesu vx5r programming software??? Slim General Ham Radio Discussion 1 05-23-2005 02:10 PM
Powered by vBulletin®
