Uniden PRO710E (UT-316)
TRANSISTORS
SYMBOL
DESCRIPTION
PARTS CODE
Q001
TRANSISTOR DB-259 2SC1675-L
BDBC1675111
Q002
BDBC1675111
Q003
TRANSISTOR DB-295 2SC1674-L
BDBC1674111
Q004
FIELD EFFECT TRANSISTOR DC-019 2SK192A-BL
BDCB0192533
Q005
TRANSISTOR DB224 2SC945A-Q
BDBC0945507
Q006
TRANSISTOR DB-331 2SC2166-C
BDBC2166103
Q007
TRANSISTOR DB-228 2SC2086-D
BDBC20E6104
Q008
TRANSISTCR DB-301 2SC941TM-O
BDBC0941523
Q009
BDBC1675111
Q010
TRANSISTOR DB-003 2SA733-P
BDBA0733115
Q011
BDBC0945507
Q012
BDBC0945507
Q013
BDBA0733115
Q014
BDBC1675111
Q015
BDBC0945507
Q502
TRANSISTOR DB-434 2SD895-E
BDBD0895105
Q651
TRANSISTOR DB-744 2SC2814-F5 TAPING
BDBC2814641
Q652
BDBC2814641
Q653
TRANSISTOR DB-743 2SC2812-L5 TAPING
BDBC2812642
Q654
TRANSISTOR DB-048 2SA1179-M6 TAPING
BDBA1179643
Q655
BDBC2812642
Q701
BDBC2814641
Q702
BDBC2814641
Q703
BDBC2814641
Q801
BDBC0945507
Q802
TRANSISTOR DB-432 2SD1348-R
BDBD1348117
INTEGRATED CIRCUITS
SYMBOL
DESCRIPTION
PARTS CODE
IC001
INTEGRATED CIRCUIT TDA1220BU
BDEY0889001
IC002
INTEGRATED CIRCUIT M5223L
BDEY0582001
IC003
INTEGRATED CIRCUIT SM5124A
BDEY0891001
IC004
INTEGRATED CIRCUIT TDA1905
BDEY0603001
IC005
INTEGRATED CIRCUIT HA17808W
BDEY0483001
DIODES
SYMBOL
DESCRIPTION
PARTS CODE
D001
DIODE 1S1555
BDAY0181001
D002
DIODE 1S1555
BDAY0181001
D003
DIODE 1S1555
BDAY0181001
D004
DIODE 1S1555
BDAY0181001
D005
DIODE 1N60AM
BDAY0001001
D006
DIODE: ZENER HZ-6C1
BDAY0269019
D007
DIODE 1S1555
BDAY0181001
D008
DIODE 1N4003
BDAY0133001
D009
DIODE 1S1555
BDAY0181001
D010
DIODE 1S1555
BDAY0181001
D011
DIODE 1S1555
BDAY0181001
D012
DIODE 1S1555
BDAY0181001
D013
DIODE 1S1555
BDAY0181001
D014
DIODE 1N60AM
BDAY0001001
D551
DIODE: LED LL-2253YL
BDAY03B400l
D552
DIODE: LED GL-9HD4
BDAY0351001
D553
DIODE: LED GL-9NG4
BDAY0353001
D554
DIODE 1S1555
BDAY0181001
D555
DIODE 1S1555
BDAY0181001
D556
DIODE 1S1555
BDAY0181001
D557
DIODE 1S1555
BDAY0181001
D558
DIODE 1S1555
BDAY0181001
D559
DIODE 1S1555
BDAY0181001
D560
DIODE 1S1555
BDAY0181001
D561
DIODE 1S1555
BDAY0181001
D562
DIODE 1S1555
BDAY0181001
D563
DIODE 1S1555
BDAY0181001
D601
DIODE 1S1555
BDAY0181001
D602
DIODE 1S1555
BDAY0181001
D603
DIODE 1S1555
BDAY0181001
D604
DIODE 1S1555
BDAY0181001
D605
DIODE 1S1555
BDAY0181001
D606
DIODE 1S1555
BDAY0181001
D651
DIODE 1N60AM
BDAY0001001
D701
DIODE 1SV73-EB
BDAY0220001
D801
DIODE: ZENER HZ6C2
BDAY0269009
D802
DIODE 1N5401
BDAY0245001
D803
DIODE 1N5401
BDAY0245001
D804
DIODE 1N5401
BDAY0245001
D805
DIODE 1N5401
BDAY0245001
Copyright © 1998,1999,2000 CBTricks.com
