Uniden Trucker PTC104 (UT-332Z)
Exploded View Parts List
No.
DESCRIPTION
PARTS CODE
PANEL:FRONT ABS CR PLATING
GCMF192013Z
2
OPTICAL FILTER:DISPLAY AS GRAY SMOKE
GCMZ392025Z
3
CH.KNOB:INNER ABS CR PLATING
GNBZ492014Z
4
GNBZ492015Z
5
COYER:BOTTOM YINYTOP,SB-K08,E-TYPE
HCMB205980B
6
COYER:TOP YINYTOP,SB-K08,E-TYPE
HCMT205979B
7
CHASSIS:REAR SPCC 1.OT ZMC
HCSR392021Z
8
CHASSIS:SIDE SPCC, ZMC, 1. OT
HC55316749Z
9
HOLDER:METER SPCC1. OT ZMC
HHDM492024Z
10
SHIELD PLATE SPT 0.3T NONOIL
H5DP402163Z
11
PLATE:ESD (A) SPTE0.3T
HSDP492019Z
12
PLATE:ESD (B) SPTE0. 3T
H5DP492020Z
13
PLATE:CONTROL ALP 0. ST SILK
JDPA392018A
14
ID PLATE:FCC ALP O.5T
JDPF392023Z
15
HOLDER:LED EPT BLACK
LHDL41301LZ
16
HOLDER:LED EPT RUBBER BLACK
LHDL492022Z
17
CAP:KNOB URETAN RUBBER BLACK
LNBZ492016Z
18
CAP:CH. KNOB URETAN RUBBER BLACK
LNBZ492017Z
19
BLIND HIMERON 0. 3T BLACK
RBLD492028Z
20
CUSHION NEOPLEN SP.
RCUN492058Z
21
WOOL-COATED PAPER:WOOL TACK WOOL PAPER, 2S*10*0. 3T
RUTC403306Z
22
WOOL-COATED PAPER:WOOL TACK WOOL PAPER, 10*1SO*0. 3T
RUTC40386SZ
23
INSULATION PLATE MYLAR, 0. lT
RZEB4167S7Z
24
INSULATION PLATE PYC, 0. ST
RZEB420017Z
25
SPRING PLATE: KNOB D6. 02XL9. S3
TSTD000003
26
RIVET:AL, ID PLATE D3. 2X5
TSTD0213250
50
SCREW:FLAT HD + M3XS NI
SSC1133005N
51
SSCW133005N
52
SCREW:BIND HD + M3X6 BNI
SSCW193006B
53
SCREW:BIND HD + M3X6 NI
SSCW193006N
54
SSCW193006N
55
SCREW:BIND HD + M3X8 BNI
SSCW193008B
56
SCREW:BIND HD + M3X8 NI
SSCW193008N
57
SCREW:TAPTIGHT BIND HD + M3X6 NI
SSCW343006N
58
HEX NUT M3.O ZMC
SSCW430030Z
59
NUT:FLANGE M3 ZMC
SSCW480030Z
60
SCREW:P TIGHT BIND HD + D3X8 NI x3
SSCWB03008N
101
SCREW:MOUNTING ABS INST CLR BLACK
GM5C405736Z
102
MOUNTING BRACKET SPCC, 1. 6T, ZMC
HBCT4060S8Z
103
HANGER:MICROPHONE SPCC, 1. OT, NI
HMHG402919Z
104
WASHER: RUBBER NEOPRENE, BLACK, 7*15*2.OT
LW5R400638Z
105
LABEL:WARNING,DC CORD PAPER, PRINT
PLBC419000Z
106
SCREW:TAPPING ROUND HD + D3. 5X8 NI
SSCW293508N
107
SCREW:TAPPING ROUND HD + DSX1O NI
SSCW295010N
108
WASHER:LOCK D3.5 NI
SSCWS3003SN
Copyright © 1998,1999,2000 CBTricks.com
Please join the CB Tricks E-Mail group or e-mail us at webmaster@cbtricks.com and send a message if you discover a problem.
