Uniden Trucker PTC104 (UT-332Z)
ALIGNMENT OF TRANSMITTER
Test Equipment Required
Power Supply: 13.8VDC
AF oscillator: 1 kHz
Oscilloscope
AF Attenuator
Power meter
AC Voltmeter
Preparation for Alignment
PA/CB: CB
Mic Gain: Max.(CW)
CH9/OFF: OFF
CA/SWR/MOD: MOD
Alignment Procedure
Step
Preset to
Adjustment
Remarks
TX 19CH No Mod.
L18, 19
and L21
Connect the oscilloscope to TP4.Adjust coils for maximum reading on the oscilloscope.
2
TX 19CH AF mic. in: 10mV
L11 and L15
Connect the power meter to antenna. Adjust coils for maximum reading on the power meter.
3
Same as step 1
L11
Adjust L11 for 4.0 W reading on the power meter.
4
Same as step 1
VR3
Adjust VR3 so that just indicated to TX PWR "4".
5
Same as step 2
VR2
Adjust VR2 so that just indicated "MOD 100%".
After the alignment, lock L11 using wax.
4. Test Equipment Connection
Copyright © 1998,1999,2000 CBTricks.com
Please join the CB Tricks E-Mail group or e-mail us at webmaster@cbtricks.com and send a message if you discover a problem.
