B
Thanks for that info.
Very strange that there isn't a VR to adjust the SWR meter calibration on the main board.
There isn't an internal sdjustment for the SWR meter on my 95T2 either.
Must be a fixed resistor...
I know that Some radios also have such an adjustment. If they don't; then there must be a fixed resistor that can be changed out to a variable - so that it can make the built-in SWR more reliable.
XLNT!!!ROB -
OK. Now I see what you're getting at. To be able to align the SWR meter in the Galaxy Pluto, locate R212. It is a 1K ohm resistor between VR14 and VR16 in the rear center of the main board. Remove this resistor and replace it with a 2K ohm pc trimmer pot (Cermet multi-turn, if possible).
To align the SWR meter, connect a 50 ohm dummy load to the radio, and with the SWR/CAL switch in the CAL position, key up the radio and adjust the CAL control for the proper reading on the meter. Then connect a 100 ohm dummy load to the radio. With the SWR/CAL switch in the SWR position, key up and adjust the trimmer pot until you get a 2:1 reading on the SWR meter. That's all there is to it. You can check the linearity of the SWR circuit by connecting a 150 ohm dummy load to the radio and seeing how close the meter reading is to 3:1.
- 399
RE Galaxy Pluto.
I have just purchased mine from a local radio ham,and as far as i am aware the Galaxy radios with names,ie Pluto arent actually made by Galaxy.
The Galaxy Melaka was built by Ranger Inc overseas for the Nochman Bros. in New York. They also imported and sold the Pluto, Saturn, Saturn Turbo and a few other non "DX" models. No contact number, no warranty and no returns. Supply and demand was the only thing they had going for them until a new kid showed up in town that gladly offered everything mentioned above and more.
