T match circuit
Crusher
Well-Known Member
May 12, 2007
841
388
Louisville, KY
Thinking about doing a T match circuit for input of a 4 tube 572B box. but never did one. Can anyone pont me in the right direction? Thanks in advance.
T-match circuits are typically used for antenna systems that have a wide range of reactances/impedances. Why do you want to use it on the input of an amp? I use a common pi-network matcher on my untuned amp. Works great.
yeah i can use a couple of trimmer caps. just i seen a few using the 2 inductors and1 tuning capacitor and wanted to try it. trying to save a few dollars in parts.
I thought that T-network were primarily High Pass Filter; shows you what I know....
Electrically, in your application, the "T-Match" is a paralled tuned circuit that will be fed with a Capacitor that is tapped somewhere down the coil.
Stick with the tried and trusted Pi-network.
  • @ Wildcat27:
    63Sprint has left the room.
