is there a reason why
well thanks for the thought hooked. I'm glad you could at least hear me a bit, maybe I'll catch you on there another time, the band died right out though I did move up through the frequencies and made one more contact in puerto rico but He started fading out as soon as we made contact only talked long enough to give callsigns and receive readings. I said 73's quickly because I could tell I was losing him.
I'm going to give hamming a break for a few hours, I'll be back on 28.3500 at 3 or 3:30 ESTdepending on how the video gaming is going. you know I can't quit whilst on a roll.
never tried this before,..... lets see if it works
QSO/SWL real time lists - NA - 28
I "spotted" you on the cluster
yep,.. it did work! I wasn't sure if i could post a live link on here
when you select the MAP function instead of the written listing,..... there you are on one end of the red line (sporatic E) and me on the other end.
btw, this is a good cluster for the high bands,.... you can tailor the VISUAL MAP for just the bands you are interested in.
  • @ Wildcat27:
    63Sprint has left the room.
