CRC Contact Cleaner
silvereagle1
174
21
Hi All .Dose anyone use this cleaner? If so is it safe to use on the boards and switch's It dose no say on the can so befor i spray it down I thought I should asked. Thanks God Bless.
i have a can right here .i use it on buttons,switches,contacts,ect,ect.....
if your going to spray a whole board or something let it air dry awhile before powering it up .
it does not contain any lube so it should be fine on a board .test in a small area first to be sure .or test on a scrap board .
Believe it or not simple-green works also I have used it on TV boards, just rinse off with water and let dry, works great!!!
  • @ Wildcat27:
    63Sprint has left the room.
