Any advice on where the mic gain on radio and on bottom of mic should be roughly? I can seem to get any call backs with the d104, is there a way to
Check audio without talkback?
mine is barely opened up and the mic gain on radio is all the way up...but mine is stock,not peaked...73 de JW i figure if it needs more pwr,get a amp...
Ok, i just cant seem to get it right. Ive tried all different settings on mic and radio gain. There is a squeal in my power supply unless i turn everything down low enough, that the needle on my external modulation meter is low. The best results i get are with my stock galaxy mic. The stock ranger mic is poor modulation results also. I replaced the battery in the d104 and didnt seem to change anything.
hello friend is that the latest model 2950 dx you are using if so what are the plus points over the older model i currently own a 2008 model 2950 dx i hope to upgrade january next year
I cant answer that question, i just picked this thing up
Used on saturday. Does it show on radio when it was made? Ill have to look when i get home, i can tell you im impressed with it over my galaxy 949 dx. I had the recieve mod on my galaxy done and the stock
Recieve on 2950dx seems much better. It also seems to have more swing on ssb. I just cant figure out how to make this d104 work with it.
