Been trying to find a short, it shows 25-32 ohms from board ground to B+ . I've removed and replaced all the E-caps , nothing there. When I change band switch it will change from 25 ohm to 35ohm then back to 25 ohm. All IC's work, it actually tx and RX. But freq an ch don't match up. It had Chanels and unlocked Clair. I've returned it all to original. Cannot visually find any more cut components, traces or diodes. Short of pulling each part out, I am trying to find a way to isolate sections. The channel switch board does get warm, but with the short it rises from 13 to 18volts in a few minutes to a few hours. Thanks
