I Was fixing a new connector on my coax from the radio and before
I solder it together, i check for continuity/short. Well it had continuity. took it back apart, nothing was wrong, put it back together, still had continuity. Took coax off the radio, coax was Good. decided to check the radio connector and the antenna connector has continuity from center pin to shield and radio chassis! what gives anyone else ever noticed this?
