Cobra 25 LTD TRB-1 Echo board / Galaxy 80 Combo
Switch Kit
Well-Known Member
Apr 6, 2005
3,595
135
63
100_9971.JPG 100_9980.JPG Second generation 25 LTD with TRB-1 echo board very light talk back applied (RF Gain is wide open and the control is tide off in the radio), with AB Galaxy 80 amp ( MRF455) radio is set at 1.5 watt dk with a 20 watt pep audio swing ,can be set anywhere you want it (diode inline) NO CLIPs ! into the amp will do 20 watt DK to 80 watts audio pep . Older President 600 ohm stock mic works and sounds nicely . ( I personally would prefer a RK-56) echo set just right , dynamike set at about 12 or 1 o-clock you got a base station on wheels sounding situation . Set just right , no back ground modulation with the stock mic , (that's why I prefer the RK-56s in this situation) Radio and amp are in tip top working condition cosmatics are pretty good (amp is like new) . Comes with nice mini 8 coax jumper for radio and amp , new power cord , bracket and metal knobs. 160.00 Shipped Priority mail same day or next . Paypal works. Thanks for looking and Happy Holidays. 100_9971.JPG 100_9980.JPG
Reactions: ExitThirteen
I guess things have changed around here a bit ? then again I've been out of the loop for a while now . I'll drop the combo down to 120.00 Shipped Priority ...........thanks for looking and Happy Holidays.
  • @ Wildcat27:
    63Sprint has left the room.
