i need the wiring code for a shure 526t to a icom 6 pin
thanks in advance
jon
Aren't ICOM mics normally 8 pin?
its a icom 718 sorry about that it may be 8 pin. i have not opened the box yetYep. It would help to know which radio your wiring for. The mics manual is posted all over the internet. You should be good to go.
http://cdn.shure.com/user_guide/upload/450/us_pro_526t_ug.pdf
thanks
jon
thank you
thanks ill do some researchthe shure is a "low gain" mic and may (or may not) sound "mushy" on the 718.
a Heil ICM ($$$$) will sound GREAT!, jus sayin.
Good luck
A mod must be done to radio or mic due to ICOM placing 8vdc on pin one(Audio) to power the're mics.
All the Best
Gary
