Midland 79-290
sdmahr
154
31
38
I've been searching for an alignment procedure for this radio for some time now. I'm looking for test points, coils, and frequencies at test points.
Appreciate any help. Thanks
Scott
well after searching the web I could not find the manual and knew I had seen one. I have it on my hard drive. how can I get it to you if you still need it?
79-290 full service manual. I tried to put a link up to have you copy it but would not come through. so I need your email address to send it to you.it is a zip file with 30 pages you will have to unzip it
Sonoma, I also need this service manual. Sent you a PM.
Thanks!
SSB-109
I am still here but I lost my hard drive and not sure where I saved it to.flash drive or DVD. will see if I can find it. I have given it out to a lot of guys. hopefully one of them could send it to you. will look around and see what I can find. I will need you email address sent to me in a PM so I can send it to you when I find it.
I know this is a very old discussion but I'm hoping Sonoma is still on here. I have search the web for alignment procedures for the Midland 79 dash 290 and cannot find it anywhere. Sonoma, I hope you're still there buddy. I need your help.
He's still around and hopefully he still has the manual. I searched and don't have one anymore. The adjustment points are available but not the alignment procedure. If it's just off freq it shouldn't be too hard to fix.
pm me your email and I will send it to you
I sent you a PM in case you do not know how to start one. it is a little tricky on this site
  • @ Wildcat27:
    63Sprint has left the room.
