Shadetree Mechanic
Delaware Base Station 808
Sounds like the rectifier is dead. The question is why the second one is dead. If there is a short in the regulator, and you hooked up the new one then the short killed it too.
Good luck on your quest, if you get the same results with the new rectifier, go through this thread and soak in some of what has been shared already, the portion before the regulator board is really straightforward. Line level A/C gets transformed into a much lower voltage, the lowered A/C gets rectified (becomes D/C) and moves onto the regulator board.After I checked the 2 AC lines from the transformer I switched my meter to dc mode, then I put the black lead to the ground post on the rectifier and the red lead to the positive post on the rectifier. When I got zero, I moved the ground to chassis ground to make sure.
Then I just double checked it with my oscilloscope. I put the probe on the ac lines and hit autoset, got a great wave pattern. Moved over to DC line and got nothing, even after auto set and manually adjusting my volts per division. I get a good wave pattern from the AC volt lines Nothing from the DC line. Just a flat line.
Record Details: Power supply failure in the DX2517 base radios.
Galaxy DX2517 Radios: Locate transistor TR602 and replace with 2SD2531.
Recommend this update for all DX2517 models coming in for repair as SOP.
That's correct.
Have you isolated the rectifier, removed anything that connects to the output of it?
This isolation can help you check the first stage, and remove any possible issues that may be downstream.
Are taking your ground right off the rectifier?
