My rs pro 2046 lost its memory
Rwb
tell the devil im gettin there as fast as i can,r
Jun 30, 2018
3,778
4,949
273
69
Does it have a battery? Or something else? Takes an hour to program then turn it off n 5 minutes later all is lost
All the Radio Shack/Realistic scanners I've owned that used a battery for memory retention used a 9 volt cell on the back of the radio. If there is not battery compartment I'd guess that it uses a capacitor to retain memory.
Reactions: Rwb
it dont have a battery.ive owned it since new. However left it on my power supply turned on for 24 hours n PRESTO it must built up a charge.least its holding frequincys . Internal capacitor must need a charge
Yes, it needs to be powered up every now and then.
Just refereshes memory.
There is a CB Tune up Manual - those old Cu thingys...that talked about the Pro 2026 and a power supply upgrade that replaced a keep alive cap.
Might be around this forum.
Reactions: Rwb
usually every 3 months i fire it up.but missed it last 6 months thi time.but after 24 hours on it woke up
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
