Connex 360014B what the heck?
Low_Boy
Sr. Member
Jan 21, 2010
1,931
1,193
173
Rochester N.Y.
Connex 4300 HP. What is this from cathode od D10 to ground
Never heard of this or ever saw it before.
Hows the S meter working on that is it working as expected or maybe kinda different than normal
Meter works perfect.
I believe VR1 is the S meter adjustment in these radios if that is working ok I don't guess that cap is a problem it would be interesting to see what the result of unsoldering one end and see if that has any effect I'm going mostly on memory on these I have worked on many of this chassis and I know what D10 is but can't remember more than it is in the S meter circuit.
What is the value?
Thinking it's a replacement for C33 - or a method to add more "smoothing" to the S-meter / AGC stuff.
I'm in the same camp with you on that observation at least that would be all that I could see being accomplished in that position. I don't know about you Andy but my problem always stems from not knowing if the person that did this actually understands what effect it would have or was is just a hale mary kinda thing.
  • @ Wildcat27:
