Reminder: ...................Smoked
I had an Imax 2000 get hit once. Blew the base apart right where the fiberglass meets the aluminum mount. The little yellow cover on the tip of the top section had a tiny 1/16" burn spot right in the center.
She then layed over on its side on top of my garage. Fiberglass splinters all over the ground below. I was disconnected at the time thank the Lord. Coax, RG8X, tested fine but I replaced it for good measure. The only electronics it took out was my Radio Shack PRO 52 handheld scanner. And it wasn't even connected to an external antenna or plugged into the wall wart!
The moral...... lightning is a cold harted B**ch!
You know I might need a parts radio soon, you should give it a proper burial in a USPS flat rate box. Haha.
I'm sure that Frankenstein 955 Porkchop Stryker you have built will definitely need some transplants. That thing sure has the cool factor. Hope you can find a way to get a handle on some variable power for it. Running WOT can't be good on it.
Reactions: Rwb
Sure sorry to hear about that. We had that whole band of bad weather swinging through this whole area. Lightning all over the place here. Sorry to hear it got you!
Hooked my old PC66 and antenna acts fone swr is still 1.1/1. Gotta break it down and inspect before running linear on it. Been told the amp board is not much, could get lucky and other things ok.....have, I don't count on that......I'm Irish.
Reactions: Rwb
Did ya give it a 21 gun salute firing squad burial?
No....but the thought of making a video of using it for target practice did cross my mind.
Reactions: Chevboy0167 and Rwb
  • @ Wildcat27:
    63Sprint has left the room.
