CB Antenna choice?
Which would you choose?
  • Total voters
    19
@Rick, I'm hoping to use either a mfj 259c, which the techs at work call "Marginal " or their rig expert. I'm thinking that they also have a mfj266. the Captain should
Reactions: Capt Crunch
i have had the 102 ball mounted TDC of the roof.
but the best? maybe not for every situation.
if they could make one out of flexible aluminum or copper plate a 102 then yes, possibly the best
Reactions: undertaker
I like the pred 10k
But I've used the 102 whip with the 6 spring for yrs and that thing always amazes me esp DX
My Predator 10K 27in beat out a 108 inch whip with a riser on my Grand Marquis. By a hair but a difference was seen in transmit and receive with a base station 15 miles away. I mean in no way was it done like a tech but what we did it was noticed. It was just a dead key both ways.
If properly mounted there is not a mobile CB antenna made that will perform better than the 102" whip.
Actually its 108 for 11 meters. 102 plus a 6in spring(gulp) or a riser/adjuster usually at least 10in, mine is the 12 in but I don't see any more for sale just the 10.
  • @ Wildcat27:
    63Sprint has left the room.
