mean well power supply
kaos513
Sr. Member
Apr 10, 2014
2,390
731
123
44
Putnam county,NY
hello guys im trying to find help on how to install a power switch on the mean well power supply can't seem to find any ideas would be great thanks.
Cut the black wire in your AC line, then attach your switch between it. The black wire is "hot" concerning all household AC. I know some people get confused thinking it's ground like most everything else that involves DC. Don't trust your house wiring either. Get a plugin tester at Loews or Home Depot to make sure your wall socket is wired properly.
Removed hot line from psu which is black, tied it to black wire coming out of switch capped em together now middle wire went to + line on psu the 3rd wire is neutral works good now.
Below is my prototype power supply still working on it card board is template to transfer to front face case
your power switch should have NOTHING to do with the neutral line.
if you have incorporated your neutral (white wire labeled 'N') into your power switch then you have done something wrong and dangerous.
with the way it looks in your picture, depending on how you connect it, you will be directly shorting your hot AC line to your neutral and will hopefully pop your circuit breaker before it damages anything else.
the way it should be will be like this:
on your AC plug, you will notice that the two prongs aren't the same width.
one of them is wider than the other, which corresponds to a wider hole in the outlet, thereby forcing you to plug it in a certain orientation.
the smaller prong is the HOT (black wire, labeled L) wire, and the wider prong is the NEUTRAL (white labeled N) wire.
take the wire from the HOT side of the AC cord, and wire it to the middle terminal in your switch.
now take the wire that goes from the "L" terminal on your power supply and connect it to one of the other terminals on your switch.
now take that white wire off of the switch and throw it across the room.
now check your switch and make sure that the two terminals with wires on them are connected when the switch is flipped UP.
if they are connected when the switch is flipped DOWN, then take the wire off of the one end terminal and put it on the other end terminal.
rocker switches work 'opposite' meaning that when the switch is up, the middle and bottom terminals will be connected.
when the switch is down, the top and middle terminals will be connected.
sure hope this keeps you from burning anything up.
LC
Reactions: sunbulls
  • @ Wildcat27:
    63Sprint has left the room.
