I posted about finding a face plate for a ts dx500v, I forgot to mention it has whiteline on the face plate is this the same as the ts dx500v inside?.the only change I can see is there are no padding resisters,also is there a problem with removing the var.pot,i see no use for it as I will be adjusting the drive with my magnum 1 radio thanks 303
