Xiegu G90 (repost in own thread)
It seems to tune just about anything but the radiated power decreases as more power gets wasted (lost in tuner) tuning a non resonant antenna. I have had a great time on 40m with an resonant inverted V. 15w will get you round the world on 40m if conditions are right.
There might be a work around to operate the G90 out of band without cutting the diode. It is a bit clunky and have not had much time to examine it further. I was not aware that I had the G90 in split mode and was wondering why the swr was off the scale on 40m. Got a phone call. 'Stop transmitting your ham call on ch 35' plus a few more kiwi expletives about my operating habits. I looked at the display. Ch 35 was on vfo B. Well well well. Fancy that. Bother Me!
If you are in Split mode
And vfo A is in band
And vfo B is out of band
You will TX on vfo B.
Just need to hit AB button to rx on B after you stop tx.
Hey..I said it was clunky!
Both vfo' s out of band and tx error and no tx.
I am posting this so others don't make the same mistake and tx out of band.
That workaround does seem to TX out of band, but as you say, it is a bit clunky.
I have had a G90 for several months and enjoy it, but it is not perfect. The biggest issue I have with mine is that I occasionally lose my receive, but when I cycle through the preamp button, the receive returns. Not a big issue, but I guess it is something unique to my radio ? Perhaps I should reach out to Radioddity, as that is where I got it, before the warranty period expires.
Also, the NB seems to have no effect as far as I can tell, and you need to adjust the NB width as well, or you can lose your receive.
I did update firmware to 1.7 shortly after it was released, and I have no problems, but I don’t know if much is different. Maybe the CW decode is better, but it is touchy. You have to tune it precisely, and QSB and such will cause a loss of decode. But it is a cool feature in a relatively low priced HF rig (I paid $450 with a 10% off deal from Radioddity over the Memorial Day holiday).
I currently have a terrible antenna for HF in the house...just a 50’ length of 12 ga. wire wrapped around the room, for shortwave monitoring. The internal tuner will tune it (SWR > 5:1), but I don’t bother trying to use this for TX, as I have some portable HF antennas for that.
I do enjoy the spectrum scope, and have been using this radio more than my FT-891 for monitoring the HF bands. My eyesight is not so keen at 60 years old, but the color display helps out a lot, versus the monotone display of the FT-891. The lack of an external speaker port is a bit of a drag, but I do use earbuds and appreciate the switch (press volume knob in) from internal speaker to headphones. And in the house, I do remote the head with a DB-9 cable. That is a nice feature as well.
I had owned the original Xiegu X1M HF rig many years ago, and was impressed with it back then. I was even able to upgrade my original model to the later model with the nicer display, by replacing the front panel. I did sell the radio, but it did work and I was impressed with Xiegu’s commitment to their product, and the continued development of their product line. No, it is not a KX3, but the G90 is a decent little radio for the money.
I just filled the back of the microphone with hi density foam to see if it reduces the bassy-ness of the SSB tx audio. Some "in radio" means of adjusting the TX audio would be useful as the compressor doesn't seem to be doing much. I have had to reduce the mic gain to 12 for my voice so maybe the compressor will have more effect. Still have a lot of testing and learning to do. But the radio is delivering on the receive side.
Reactions: AudioShockwav
No matter what carrier level and mic gain. It rolls back to almost nill. Haven't check lower bands yet. Unless I have settings wrong or defective unit, it looks like a TURD on AM.
No big deal. It's a SSB unit for me. Made a few contacts on 10 meters today. Very weak signals, but I pulled them out. I had favorable reports.
I did something Similar using a plastic 'stick on' wall hanger. Radio still fits in the box but I have to put it in upside down.
It has the advantage in that it can be 'hung' in a somewhat vertical position if something suitable available.
Interested to get the details on the bail you bought from China as that would be the better all round option.20191002_131649.jpg 20191002_131727.jpg 20191002_131820.jpg
    Tucker442 has left the room.
    LIVE 10:00 AM EST :cool:
  • @ Charles Edwards:
