Nitro knobs ring lights MASSIVE FAIL. Dern!
nomadradio
Analog Retentive
Apr 3, 2005
7,012
11,223
698
Louisville, KY
www.nomadradio.com
File this under "nice try, no cigar".
Here's the pinball-table "post light" with a 6mm control shaft. The hole is too small. Drilling it out would likely destroy the LEDs.
The company Comet Pinball doesn't post mechanical drawings of their stuff, so this is how we find out the size of the center hole.
Nothing ventured, nothing gained.
At least not this time.
Looks very cool.
Minimum order 50 units for the RGB version. 500 units for white.
And no order info on the web site. Looks like one of those "request a quote by email" distributors.
A cool page I hadn't seen before. Thanks.
I’m glad you posted this. I was one of those eager followers who were waiting for the results. It was in my mind also, to see if the hole could be enlarged. Guess that answers that.
I thought you would have posted it under the old thread that I was following, I’m fortunate that I looked and saw it here!
My cheap chinese caliper says the hole is 4.5mm diameter.
I don't see a full 3/4 of a mm around the rim of the hole before it starts to cut into the plastic body of the LEDs.
Besides, if each one takes that much labor to actually use, the customer won't want to pay what all that adds up to.
The "home gamer" might want to try it. If I can't make it a commercial proposition I'm not interested.
It’s a tight fit but I think these will work I hand teemed them
They won’t fit over a ten turn clairifier though but these will indeed work.... step right up folks you too can have retina burning blue nitro light rings
Hopefully y'all don't get to unhappy with me for bringing this thread back to life. However I've been wanting to do something to give my radio a little custom look without looking too cheesy. I liked the look of the Grant lt, yet didn't care for the green. From what I have seen, nobody made anything I liked the look of. I never wanted red, green, & blue is just too hard on the eyes at night. I did my own led lighting.
I used 3mm uv leds. I ran 3 leds per resistor for most of them. Tapped into switched power to run them all, no extra switches. I installed them into the back of the steel that the knobs & switches mount to. I did have to grind the dome down/off so that they would fit in the .110" space between that & the plastic faceplate.
I did have to enlarge the holes in the plastic faceplate behind the knobs to get it just right. When the knobs are installed, you don't see the larger hole. Just the glow from the light. It is bright enough to see the purple glow during the day providing that you are someplace semi shady, & it is not overpowering at night. Kind of a fun project for a couple of days.
Nice Project, good work...
Are you aware of "dimple"?
The "notch" on the top of the Dome can be sanded to reveal the plastic "white" underneath.
IF you are creative, you can use clear glue to make a Fiber Optic path to the top notch and illuminate the notch and allow the chrome of the plastic around it to hide the translucence, it makes the "mask" so you can easily see WHERE in rotation the knob is at, not just the knob ring.
I've seen radios arrive to the shop with multi color purposed lighting to help the driver find "home plate" by color coding the lighting, Red for Volume Power, Green for RF Gain, Amber for Squelch - stuff like that. - we had a guy at the shop that did this kind of custom work and was contract only - never knew how much he charged but he had a lot of expensive toys he'd play with while waiting for work - let's say he didn't really need the job, just something to do.
Reactions: walterjn
Thank you. I think I'm understanding what you're saying, the dimple on the end of the knob that you can see in good light or feel. I've kinda been trying to get something like that done, I just haven't given it too much thought as to how. I have considered a clear resin, I'm just not too sure as to how well that would work.
  • @ Wildcat27:
    63Sprint has left the room.
