why does 1/4 wavelength have to have a ground plane and 1/2 doesn't?
LUFER
New Member
Feb 10, 2020
3
Hello everyone, does anyone explain?
I know that an antenna that has half a wavelength does not need the ground plane (example a dipole antenna) and when using a wavelength of 1/4 it is usually necessary to have the ground plane (planar antennas [PCB]).
My problem: I can't understand why we need to use a ground plane at 1/4 wavelength and 1/2 wavelength not needed.
Please could also provide source of relevant information, examples, books or scientific article, something like that.
Regarding the subject
Well, while you're looking thru the sties the above mentioned, I'm just going to add a simpler effort to look at the way you are thinking antennas work...
1/2 Wave antenna?
Divide it by 2 - you get 2 - 1/4 Wave antennas Right?
Where are you feeding the antenna? Where are you attaching your COAX - also known as FEEDLINE
You say why does 1/4 wave need a ground plane - but 1/2 wave doesn't...(well, yes it does, but it's not what you think)
Re-read at the above carefully. You can look at this problem in different ways, change your point of view. How? Start with - It's in how you're feeding the antenna - in a 1/2 wave, it's being 2 - 1/4 wave antennas, you feed it at one end.
Now take a look at your other antenna - your 1/4 wave antenna. It is still the same size - BUT YOU FEED IT AT ONE END, IN THE MIDDLE - You connect one part of your coax wire to it - use the CENTER for that - connected the SHIELD to the other 1/4 wave feed it there THAT THE OTHER HALF STARTS FROM (The Middle) AND GOES IN THE OPPOSITE DIRECTION. Only you don't make the other half, the ground image does. Put the 1/4 wave with the ground image of another 1/4 wave - you make a 1/2 wave LENGTH TOTAL overall antenna correct? Only you feed it at a 1/4 wave point (the middle) - but you make a 1/2 wave antenna you just let the ground image form from the COUNTERPOISE you need to make that 1/4 wave work.
If you feed a 1/4 wave antenna - you sill need ANOTHER part of it - that missing 1/4 wave is in your ground image...your Counterpoise...or what you use your vehicle - or any other metal you've attached that 1/4 wave antenna to - used as a means to COUNTERPOISE (Offset a lack of) otherwise.
Reactions: LUFER
Hi Lufer.
To keep it simple I will make a short statement and simple illustration (to understand the technical aspects of your questions answer requires study).
Statement:
All antennas of every type require a counterpoise although it is not immediately recognized as such.
Illustration:
To leap upward you must squat and use your legs to thrust yourself upward against the floor. Simple. Now suspend yourself from above, take the same squatting posture with your legs and thrust them downward. You go nowhere because you have nothing to thrust your legs against.
RF is the same. It needs something against which to "push" or "thrust" itself against in order to project into space. Without this opposing something it will go nowhere just like your leap does not happen without the floor.
For any and all antennas there is an opposing current equally providing the floor against which to "push" or send your signal on it's way. Whether you provide it by a groundplane or not doesn't mean it isn't necessary or that it doesn't find one by some other means.
Knowing all antennas need one introduces the real question - Where is the counterpoise for this antenna?
Study, and continue to ask questions.
Lufer, I see the distinction above in bold type, that you bring to the CB Antenna Section. Maybe a visit to the Ham Antenna Section will get you the proper information for your project.
Reactions: LUFER
greetings lufer, i don't get on much any more, hope you enjoy the hobby as antenna making has been the most enjoyable aspect of the hobby for me.
A half wave DOES need a ground plane, so does a 5/8 wave or any other combination of wavelength for an end fed antenna.
I know that an antenna that has half a wavelength does not need the ground plane (example a dipole antenna)t
A dipole isn't end fed, it's fed in the centre therefore the "other leg" acts as a ground.
Reactions: LUFER and Marconi
  • @ Wildcat27:
    63Sprint has left the room.
