WTB: Aries A-SWR 460 digital meter
Mine is still in the truck, and works as good as it ever did.
If these meters have a failing it is that the display is hard to read in bright sunlight.
Its nice to see power output and SWR at a glance every time you key up.
Reactions: Chris Millas
I have one I had to wire a straight wire on the back for power as the power jack went bad missing 2 rubber feet but I just realize how close to accurate it is I have the radio set to 2 watts on bird meter this one is not that bad off
  • @ Wildcat27:
    63Sprint has left the room.
