Hi all, new to the forum.
I have a Galaxy DX-2547 with an overheating problem. On the inside it looks to be a DX-959 chassis with a switching PSU.
The radio is factory with no peaking or tuning(Yet) and has run fine for the first 3 months. Then the problem started.
The issue is there is a transistor on the side of the chassis toward the back on the right side that gets incredibly hot within a few second after power up( not smoking...yet but I can smell it after a few min). This happens in all conditions, antenna(SWR 1.2) and Mic hooked up or with nothing but the power. I believe its the voltage regulator as the main power wire runs to one of the pins. This problem happens when using the internal power or the external power connector. The radio operates fine when powered up but I shut in down after a few as not to let the smoke out.
I checked the voltage of the internal PSU and it measures 13.8V. Likewise my Astron RS-50A linear supply is dead on at 13.8V.
Has anyone come across this problem? I'm wondering if the regulator needs to be replaced or does anyone think there might be an underlying problem. Nothing else gets hot on the board.
Any info would be greatly appreciated!
Thanks all!
Thanks all!
