Just rebuild the tone generator in my Golden Eagle transmitter,68t. After i changed the parts out, resistors & ne2 light. I hooked it up an every thing worked fine. After using it a little while i lost the audio. It still has a dead key, just no audio. Pin 7&9&3,on the 6bq5, have no voltage. Which pin does the voltage come in on. If i knew that for sure i could check back down the line.Jim/238
