Snapped Super Magnum Antenna
Speaking of forks, try placing one on the nail or screw in the wall to make it easy to hang a picture wire over...
Reactions: Riverman
I could take the enameled copper windings off. I was wondering how to take that broken tube out of the aluminum. Any ideas ? What type of glue can I use to attach the new phenolic tube I ordered ?
See pics
Forgot a pic of the exact inside and outside diameter phenolic tube I ordered
Either epoxy or E6000 may work for adhesive.
Use hole saw blades in diminishing sizes on a drill press to remove the stump. Maybe use a multi tool to cut pieces away, then grind out the residue with a spiral tool like the Dremel.
If you don't have those tools use a drill and bore a series of holes into it from the upper broken edge and then chisel it away with a wood chisel.
If that fails put peanut butter on it and borrow a rodent, maybe a beaver...
I could take the stump out.
Reactions: HomerBB
Phenolic tube finally arrived Exact fit. Now I am wondering what kind of glue strong enough I am going to use which won’t damage ( oxidize )the aluminum housing with time.
Reactions: 2NC995
2B284415-986D-4991-B94E-AAAC654C994F.jpeg 3EFAEBF3-8FF0-4F64-9B80-E2791824ED1D.jpeg C65F77BB-C551-4032-BC89-8C55B9D08C90.jpeg 86BAC6BD-2977-4A38-9D9B-A36C14DF602F.jpeg Here are som pics of the coil and base assembled. Next thing I have to do is to get the dimensions of the capacity hat. Mine is missing. If anyone can give me that info, is welcome.
I read on other forum that if I miss the capacity hat, antenna would be 10” longer.
By the way, The so called “ sati-lite” tip really reduce static noise as stated by Antenna Specialist ?
View attachment 38256 View attachment 38257 View attachment 38258 View attachment 38259 Here are som pics of the coil and base assembled. Next thing I have to do is to get the dimensions of the capacity hat. Mine is missing. If anyone can give me that info, is welcome.
  • @ Wildcat27:
    63Sprint has left the room.
