I recently acquired two Uniden Washington units, both in working order... for the most part. One has an awful popping crackle when turning on, and heavy crackling when changing the volume. I am trying to find a replacement for the on/off volume potentiometer for these units. I've had no luck. The only numbers printed on the part itself are "10KA" and "573F".
I swapped the potentiometers around to verify that it is indeed the problem. So now I have one that works perfectly, and one that needs some help.
