Northstar's hot August 36LSB Contest.
Here are the rules for the contest. any errors let me know.
  • Only contacts with other WDX members count in the contest. The roster may be found as a sticky thread located http://www.worldwidedx.com/threads/wdx-roster-11-30-2014.28909/
  • Channels: 36 LSB
  • Date/Time: 0001 13 Aug – 2359 15 Aug 2021 UTC. If you're not sure how UTC time works, check herehttp://www.timeanddate.com/worldclock/converter.html?p1=3875
  • Logs must be posted in the WDX Club Contest Contacts forum by the end of contest. Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest. The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread. At the end of the contest, the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
  • There is a 2x multiplier for mobile, portable, or maritime contacts. If you operate as mobile, maritime, or portable during the contest, you are credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. 3x multiplier for any contacts outside of CONUS and Canada. Make sure you clearly designate these in your log
  • No amplifiers allowed, CB legal limit.
  • Contacts will be verified against each others' logs
  • This is an "on your honor" contest and intended to be fun. Please play by the rule.
  • BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
Omg, this stuff is bad enough on ham radio, dont start on 11m too. Pshhh.
Cq contest cq contest cq contest, cq contest, cq contest, everyone is 5 and 9 all the time. Cq contest cq contest cq contest cq contest cq contest. God, make it stop! And propagation absolutely sucks, and no amps allowed? 12w? Hahahaha, good luck with that one
There has been 11 metre contests via this forum for years now.
Hmmm...just saw the rules. I know it’s the honor system but I am sure some ham will use a ham radio that puts out more then 12w. So ok...it will be the honor system. Barefoot...wink wink.
Yeah, it'll count me out as I don't currently run a standard cb on the base. Maybe if I can get the ranger 797 set up but there's time constraints on my end.
Reactions: freecell
  • @ Wildcat27:
    63Sprint has left the room.
