"Phasing antennas only has one benifit, it makes the antenna system directional. It doesn't mean you can increase your actual transmitted power, just that the power radiated can be focused in particular directions."
if we take signal away from one or several directions and "focus" it into other directions then we have increased the actual amount of transmitted power in those directions. (use the word radiated if you like, that may be less confusing) this in essence is the definition of the term "gain" as it refers to antennas and especially antenna systems. (2 or more) i believe i mentioned the several benefits in previous posts.
one other advantage i failed to mention is that since the transmitter (or amplifier) power generated IS divided among 2 antennas and feedlines, this will generally save money normally spent on feedline with larger power-handling capabilities, not to mention the antenna systems improved ability to handle higher power levels as compared with the same power level used with a single antenna/feedline of the same type and caliber. here's another graphic example of another of the benefits of dual antennas and knowing what to use and when to use it,.
www.firecommunications.com/install.txt
"The radiation pattern of a mobile antenna system is not constant."
the initial pattern generated by the antenna system is always a constant unless the antenna configuration itself changes. referring to the near and far-field aspects the only times the above statement applies is when we are dealing with changing altitudes in the ionospheric layers in skywave applications where varying heights affect the angle that the transmitted signal arrives at and leaves from the associated layers.
another instance where this may apply is when surrounding metal objects closer than 1 wavelength (or extremely large metal objects at 1 wavelength or farther out) are in the near field of the antenna system. local terrain can be included here too, including soil conductivity.
"Phased antenna systems are NOT imune to the available 'ground' of the vehicle they are on." no one said they were immune or operated totally independent of the vehicle ground. (this includes the capacitively coupled earth ground as well)
here's what was said:
another advantage inherent in dual antenna systems is that they are decidedly much less dependent on large areas of counterpoise or ground plane surface for adequate performance and matching, as long as at least the top 2/3's of each of the antennas have unobstructed line-of-sight to each other.
here's the bottom line on dual/co-phased antennas. let's say, as in hossless' case where he's running 1400 watts, (geez) let's say this is being fed into a single antenna. if he were to locate and install 2 of the same antennas in a dual antenna set-up, in the favored directions of the system the increase in signal would be such that he could cut the transmitter power in half and still produce the same signal that he did previously with the single antenna at twice the power. this is completely in line with a 2.5 - 3 db. advantage with dual antennas over a single. (in the favored directions of the system)
an added bonus also is that incoming signals to the antenna system arriving at the sides are attenuated to levels below that of a single antenna (depending on which side of the cab it's mounted on) allowing the operator to concentrate on other mobiles up and down the road to the front and the rear. this i understand is what most truck drivers are looking for. well, that
and someone who has the necessary materials and can do the job correctly to procuce the mentioned results.
as for cutting to length, the following figures should be suitable for most installations.
for 75 ohm solid polypropylene:
5.96802058445138761257121852600625 feet
5' 11.616" inches........6 feet
usable lengths: 6', 18', 30', etc..
for 75 ohm foam:
7.05311523616982172394780371255284 feet
7' 3/4" inches...........7 feet
usable lengths: 7', 21', 35', etc..
compare them to the table on fgbest, they're close enough for government work.
and just to demonstrate how non-critical the length actually is:
i have used exact 6 foot lengths (or any odd multiples) of the foam and noticed nor measured any differences in tuning or performance. best though if you stick to the figures above. all math is based on a CF of 27.205 mhz.
the information and observations above are not the result of any opinions or thoughts but instead are the result of empirical evidence and knowledge gathered and collected over the course of some 30+ years obtained through almost daily experience gained from working with and testing the configurations referred to in all of my posts on the subject.
many in the past who have attempted to duplicate the results from the information provided have not been disappointed.
"I honestly can't understand why anyone would want to use one (dual antenna system) in a 'moving' mobile." i can think of several.
which costs you more? another 700 watts or another antenna and a co-phasing harness?
</p>
Edited by: <A HREF=http://p067.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=freecell>freecell</A> at: 5/8/04 1:38 pm
