I am not sure if this is the spot for this??
Ok as suggested I practice soldering with some 3.5mm cable and some speaker wire.
I cut open the 3.5mm cable to find it has 3 wires a green, red and yellow well after testing I found the yellow was the ground and the red and green are the supply(?) so I soldered some wire to the green and red FIRST and found that wasn't right then soldered the green and yellow then wired it to a speaker with those quick connects in the back and whah-la I have sound.
Well here is where I am confused. when I plug the 3.5mm in the the ext out on the back of my CB I get NO sound, no static, no talkback. Nothing so why is that??
