Features, Pros & Cons,,,Texas Ranger TR-900 Series
C
Charger383
Guest
The Texas Ranger TR-900 Series are the newest addition to the Texas Ranger line of high quality CB radios. They feature a new face plate style and the "new circuit design" concept by Ranger Communications, Inc. Built with ruggedness, durability and reliability in mind, which allows us to offer a 2 year warranty. These models will satisfy your needs for a high performance AM only or AM/SSB radio and do it with style.
Built with the trucker in mind, the low component profile method of manufacturing the TR-900 series offers extreme vibration resistance for those rough uses such as the tough treatment that a radio receives while installed in an 18 wheeler. Continual bouncing and jarring will have no effect on these models. Plus, with the new voltage fluctuation protection circuitry, you don't have any worries about the extremes you encounter on start-ups and other varying voltage problems.
The TR-900 Series features the new Ranger exclusive "Advanced Noise Filter Circuit" for improved signal to noise ratio, providing high noise rejection capability that others just claim they have. This one works! You will instantly notice marginal signals pop in better when you turn on the switch and listen to your reception with a quieter signal.
There are four different models within the 900 Series. Each has their own unique features, and offers you a wider choice in choosing the exact radio to fit your needs.
If you desire a radio with the capabilities of receiving the weather channels, then choose either the AM only TR-939WX or the AM/SSB TR-969WX model. A feature of the Ranger WX radios is that when you switch to WX position, it will automatically scan all 7 NOAA weather channels and find the nearest one to you. Now, driving across country you don't have to try to remember which channel is for the area you are in,or keep switching channel numbers to find the weather station near you. Ranger's unique scan feature does it all for you. It also incorporates an Alert feature that will warn you of impending severe weather conditions. Both models also feature "Roger Beep" and a variable talk back control.
You don't need weather channels? The TR-936 AM only and the TR-966 AM/SSB was built just for you. With the TR-936, we have included the roger beep feature, variable dimmer control, and a variable tone control so you can adjust the sound to just how you like to listen to it. For the SSB users, the TR-966 features a clarifier control, hi/low tone switch, and a bright/dim switch.
The TR-900 Series is sure to please everyone with the new stylized case and front panel. See the below list of features common to all four models.
— 6 Digit Frequency Counter Connector — 2 Year Warranty
— 2 Digit Channel Indicator
— 2 Color Xmit/Rcv Indicator
— Advanced Noise Filter Circuit Switch
— Automatic Noise Limiter + NB Switch
— Illuminated S/RF/SWR Meter — Seperate ANL Switch
— SWR/CAL Switch
— Adjustable Volume/Squelch Control
— RF Gain Control
— External Speaker Jack
— Mic Gain Control
— Dynamic Mike Included
— Voltage Fluctuation Protection Circuitry
— Switch for Instant Access to Channel 19
— Vibration Resistant Design
— Low Noise Receiver Circuitry
</p>
The 936 is probably the all around best FCC type-aproved 40 channel CB radio ever built by anyone. If you take the extra channels and reverb from a Connex HP-4400, you have basically got a 936.
At $82.00 dirung their special pricing a couple of months ago, there is not a need to sell a Cobra 29 as this radio is head and shoulders about the C-29. Also it is a perfect Candidate for the
<a href="http://www.angelfire.com/electronic/cbdoctor/npcrc.html">
NPC-RC Conversion</a>
The only problem is that when using the extra new noise cancellation circuit there is often a muffling of the receive audio. I wonder if anyone else has had that problem and conquered it. I have seen it in every one of the ones that I sold. I have not attempeted to solve the problem as of yet.
<font color="#ffcc66">
Billy Dean Ward
</p>
</p>AKA The C. B. Doctor</p>
The only problem I been seeing is that not very many retailers are catching onto this Billy maybe that they or there techs don't realize this
Jesse
</p>
